Hi Everyone,
Long time listener, first time caller. So, my new to me '96 GTX keep dying once it gets in the water. I can connect/disconnect the DESS key while it sits in my garage a billion times and it always recognizes it and I get the lights on the gauge cluster (beeps don't work). It is also fairly easy to start. Once I get it in the water, it's hard to start, but runs fine when it's going, until I start motoring away from the launch. Anywhere from 20ft to a hundred yards and it quits like the DESS key was pulled. When this initially happened to me, I was able to get it to start after some cursing and fiddling. Now, it does not...once it's dead, it's dead. I replaced the battery today and it still had the issue, so I'm leaning toward something getting wet and shorting. I checked the forward compartment and there's minimal water in there, the gray box was dry as a bone as were wires going into and out of it. Grounds at battery look good and dry, but I have not traced them yet. My next thought is to let it dry out overnight/through tomorrow until it starts recognizing the key again. Once it does, I figured I'd start squirting water around the stern area systematically until I find what's causing the issue. Does this seem like a good plan? Is there something else I should check that may be causing this? I know there are lots of posts about the DESS post and other related items, but to me, it sounds like it's more of a electrical short...again, looking for those with more experience with this system to let me know if this is a DESS issue or not.
Thank you for your time,
Andrew
Andrew
