Chuck96gsx
I have a 1996 seadoo gsx that I was getting ready to take out. I fully charged the battery and plugged it in and when I hit the start button I got a few clicks. This used to happen before but would turn over eventually now it won’t. I thought it was something to due with the rear electrical box so I replaced everything that looked like it had corrosion and rust from moisture in the box. After doing that I used a volt reader to probe parts and was getting 12.3 on the left side of the solenoid and around 10-3-.5 on the right side after hitting the start button. When trying to start it now it just sounds like the starter is grinding it’s teeth and just spinning. I pulled the starter to check to see if it’s bad. I also pulled the plugs and they don’t look to have spark but the engine also won’t even turn when doing that. I’m just lost and need some direction in what to check and do next. I’d appreciate some help if anyone else had this issue. L
