i am a new member so let me say hello to everyone first ,,,now if any one has any ideas or suggestions on what to check ,i would be thankful,2 problems i am having is sputter and water getting in the boat some how ,the sputter is wierd when you start it it idals fine when you go to give it gas it just sputters ,,if i shut it off and restart it and get on the gas it will sputter ,if i repeat the shutting off and restarting eventually it will blast off and run fine ,like nothing was ever a problem ,but it does happen quite a bit ,,the ski set for a few years ,i rebuilt the carbs ,and replace all fuel lines and clamps ,,it ran fine before they set for a long time ,my 2nd problem is water getting in the boat ,i have filled the boat with water ,there is no water leaking out ,i started it when it was full of water i dont see any new water movement ,i checked the exuast pipe plug underneath i dont feel any moisture ,,but when i put it in the lake it is past the starter in a hour of riding ,,,hopefully i aint the only one who has had this problem ,i did notice VTS bar has quit working and does not show up on the led screen ,thats the only other thing that has just suddenly stopped thanks again and hello to all
