1995 Yamaha waverunner II misses under load
dalef62
I am working on a friends 1995 Yamaha waverunner and it develops a miss under load. I was wondering if the plug wires are the same as Seadoo's that you can cut off a little from the end and thread them back on. I don't want to destroy them by cutting the ends off and find out they are made different.
Thanks,
Dale
Thanks,
Dale
I have found the spark plug caps to be defective on quite a few of these, that is where I would start, remove the stock caps and put on a set of NGK spark plug caps, see if you problem goes away.The photo below shows the kind of caps you need to get.
I can't answer your specific question, but I do think it is a good path to be on. You need to get some known "good" to start to isolate this out.
