Hey guys i have a 2000 Seadoo GTX Millenium Edition 951, i just bought the jet ski a few days ago and it rode well, little bit of water was coming into the hull under the motor, couple of friends said it was possible carbon seal, i rode it today and i was pulling a tube and the rope got sucked into the driveshaft, after 20 min of cutting it off with a knife i finally pulled it out. Few hours after the jet ski just didnt run the same, All my guages died and the speedometer was way off. Shortly after that the whole jetski was filled with water and had no power. Then it cut off on me and would not start again. I came home and pulled the plugs and tried starting it to see if the motor was flooded. One cylinder was fine and then 2nd one spit out oil and water mix. The ski just cranks. If i give it a little bit of gas while starting it will turn on for a split second and then just die.
What are my options here? is the motor blown?
I did pour some oil down the cylinders to prevent them from rusting.
