If you just transfer a plug wire to one sitting on top, place the key on and jump the starter relay you should see a spark, the stator is the trigger to the coil/s - there is a light that many marine/motorcycle places have that clips between the plug and the king lead to make this easy. 95 was a year when ignition was changing to the security style, there may also be a spark amplifier in the primary side, you will need the schematic of your system to trace deeper into the spark outage, but if you can see the wires from the front cover and drop a ohm meter there, when you turn the driveshaft there should be some pulsing shown which is the trigger signal on 2 wires - these may be amplified before the coil, again review the schematic slowly, if you follow out to the coil with a signal then the motor will run but you could have a bad mpem box in the area of cranking relay signal or the overspeed shutoff circuit.
