Yes, RETurn line.Would it go here?View attachment 63274View attachment 63275Because if my computer going down I need to make sure of a few things, this line here goes to the fuel baffle labelled Return
Yes, to the carb inlet.View attachment 63276And this fuel line comes from the fuel filter. It would go to the fuel inlet on the carb correct? The other line from the fuel filter is going to the fuel Selector valve labelled out
Yes, 95 HX is 1 3/4 turns out and the 96HX is 1 1/2 turns out. I’m using the 96 manual. Figured they would be the same.
No, 1995 had 135 main jets and 67.5 Pilots and the 1996-1997 had 130 main jets and 75 Pilots so the screw setting are not the same.Yes, 95 HX is 1 3/4 turns out and the 96HX is 1 1/2 turns out. I’m using the 96 manual. Figured they would be the same.
I was just going to purchase the Tiny Tach but I see there are 2 models. TT 2B which you sent me the link for and TT 2A which is a little more expensive. Will the TT 2B model do for working on these seadoo’s?They are $54 on Amazon in the US.
https://www.amazon.com/Digital-Mete...ocphy=1014254&hvtargid=pla-570678540958&psc=1
I have had mine for over 25 years and keep replacing the battery even though they are "factory sealed".
The problem with some of the cheaper ones is they don't update fast enough to do much good and the TinyTach you can adjust it for different firing orders.
On the cheaper ones I don't know much about them.
