What attaches to these two ports on a 951 Mikuni carb. I’m stumped!
Sea-Doos
I need a little help fellas. Can anyone tell me specifically what lines attach to these two ports on a 951 Mikuni Carb. It’s a 2001 GTX project I took on that had hoses missing so I’m at a loss. Photos or a video would be most helpful. I’ve read some forums and they are vague with their responses to the OP’s question. Such as “this one goes to the engine” okay where on the engine? So if some one can guide me in the right direction, I would appreciate it. I’ve spent hours trying to figure it out and I don’t have any brain cells left for this step. Thanks in advance for your detailed responses.
Top line is the RETURN line to the fuel baffle, the other line is the carb pump. That one comes from the under the rear PTO cylinder. There are 2 lines under there. One is for the rave valves.
On the carburetor body there is an outlet marked "pulse." Connect it to the tube on the block (photo with a green arrow).
if you haven't already download the parts manual for your ski, it has good pics that will show you where things go, its an easy way to figure some stuff out.
