I have a 1995 Sea Doo GTX, When I first put it in the water it runs great for almost exactly 15 minutes then beeps twice then shuts off, like you had pulled the kill switch, no bogging or missing. It will start back up but only run for a few seconds.
I know this sounds like over heating but as far as I can tell it's not getting hot. I have blown thru all the water lines and engine water jacket. It seems to have an adequate flow thru the pee hole. I can put my hand on the engine after it shuts off , it's hot but not terribly hot. It seems to be a timed event, it doesn't matter how hard I run it, its fifteen minutes and it will beep twice and shut off. I can disconnect the thermal switch between the spark plugs and it will still shut off but it won't beep.
any help would be appreciated.
