I had that problem once. In the shop manual, under DESS in the electrical section it says that the MPEM cannot communicate with the CDI module. There are a few things that could cause that. A bad CDI, the 5A fuse on the holder relay (that powers the CDI) is blown, the holder relay is not supplying voltage to the CDI, the connections inbetween the CDI and MPEM are faulty. Check the fuse, check the wiring, preform the static check on the holder relay per the shop manual. If those check out, see that the holder relay supplies 12V to the CDI while cranking the engine . If all of those check out then the CDI might be bad. I had a holder relay that would turn on when the key was inserted but dropped the 12V when the start button was pressed. It took me a while to find that because it was intermittent. I wore out the starter and bought multiple CDIs before one of them gave me the 4 beep error and led me to monitor the output of the holder relay while starting.
