Shop Discount Sea-Doo Parts
195 and 215 Top Speeds?
pwgsx
Messages
1,373
Location
DFW
Water Crafts
2016 RXP-X 300
96 XP
99 GSX Limited #2
04 Speedster 200
89 JS 550
04 RXP
99 GSX Limited #1
Does anyone know the top speeds of the 195 N/A vs Supercharged as well as the 215 N/A and Supercharged models?
pwgsx
Messages
1,373
Location
DFW
Water Crafts
2016 RXP-X 300
96 XP
99 GSX Limited #2
04 Speedster 200
89 JS 550
04 RXP
99 GSX Limited #1
542 views and no one knows the top speeds, even the dealer had no clue when I called :( , time to look at a Yamaha LOL
Coastiejoe
Moderator
Staff member
Moderator
Messages
14,647
Location
FLorida, Southern Area
Water Crafts
2009 RTX X (255 hp supercharged / inter-cooled).
2010 GTX 155
I can't help you with the boat speeds...
It gets slower around here in the winter months. If no one answers in a week or so, reply to your own post to bring it back to the top...
gioakjoe
Messages
138
Location
Spring, TX
Water Crafts
2003 utopia 185. merc 240 efi
http://www.boattest.com/boats/boat_video.aspx?ID=3293
Scarab 215 HO Impulse (2015-) Test Result Highlights
Top speed for the Scarab 215 HO Impulse (2015-) is 54.9 mph (88.4 kph), burning 35.0 gallons per hour (gph) or 132.48 liters per hour (lph).
Best cruise for the Scarab 215 HO Impulse (2015-) is 26.8 mph (43.1 kph), and the boat gets 3.3 miles per gallon (mpg) or 1.4 kilometers per liter (kpl), giving the boat a cruising range of 123 miles (197.95 kilometers).
Tested power is 2 x 200-hp Rotax.
gioakjoe
Messages
138
Location
Spring, TX
Water Crafts
Scarab 195 HO (2015-)
http://www.boattest.com/boats/boat_video.aspx?ID=3265
We have not had the opportunity to test the 195 HO ourselves, however Scarab reports that with a Rotax 1.5L Supercharged 200-hp engine she'll reach a top speed of 40 mph. Testing with a Rotax 1.5L Supercharged HO 250-hp the Scarab 195 will hit 43 mph at WOT, according to the builder.
185utopia210
Messages
27
Location
Kingston Ontario Canada
Water Crafts
02 utopia 185/210
Thought they would do better than that, but then it is only a 3 cylinder....:)
Eclipse1701d
Messages
246
Location
Nature Coast, FL
Water Crafts
Current: 2007 Sea Doo Utopia 205 SE
Sold: 2007 Sea Doo GTI 130
2008 Sea Doo GTI 130
The problem appears to be size/weight to horsepower. IMHO two 155NA's would be the way to go in the Scarab 195/215.
NC25T
Messages
7
Location
Ohio
They need to throw sea doo's new 300hp motor in there
300hp from 1 motor is better then 155 hp X 2
I think it was last months boating magazine where they compared single vs multiple engines in different boats and also 3 vs 4 engines.... The articles showed how much better fuel economy would be and also how max speed was similar with less power....and also less weight.
Bobby78
Messages
24
Location
Belleville, MI USA
Water Crafts
1999 Challenger 1800 Twin Rotax - FOR SALE
2016 Scarab 195 HOI
I can verify that my new 2016 195 HOI with 250 HP does about 43 MPH at WOT.
Premix
Messages
129
Location
New Jersey
Water Crafts
210 Challenger SE 430hp
I expect comparing two jet drives versus propeller out drives to be entirely different. There's no drag of a second out drive's lower unit with jets. I'd imagine two jet pumps are better than one on boats since you're accelerating twice the amount of water. This might not be beneficial on a 800 pound PWC, but on a 3000 pound boat I expect it to be very useful.
NC25T
Messages
7
Location
Ohio
I wasn't referring to two jets vs one prop unit, but 2 jet vs 1 jet or 2 prop vs 1 prop all with the same total power.
There is increased drag with the second engine, it comes in the form of additional weigh to the boat thus sitting just that much lower in the water creating drag/friction.
I am far from a engineer thus just guessing here. my thinking on being able to push more water through two pumps is that even at 300hp through one pump your not close to the max power or flow the jet drive can move, thus it shouldnt be a concern/issue. I could see that if you are wanting say 500-600HP or more where you might be at the limits of what can be processed.... but oem power levels shouldn't be a issue.
NC25T
Messages
7
Location
Ohio
I read the article at the local book store, it might be posted on their website now?
I can't recall for sure but I do not believe they had any jet drive boats that were discussed in the article. The same argument in regards to multiple jets can push more water vs a single jet drive could be argued with a conventional prop/outdrive.
You can also load your boat up with say 300# of people to see how acceleration etc change with more weight, not sure what each engine weights I would assume at least 300#?
James.Moon
Messages
146
Location
Calgary Alberta Canada
Water Crafts
Seadoo 180SE
Seadoo 180SE 255 HP - 90-95 kph max on the speedo with only me the driver -but GPS says it's slower about 82-85 kph. Pretty zippy though - close to 50 mph
Users who viewed this discussion (Total:1)
SPONSORED LINKS
Latest posts
Usergroup
