07 rxp 215 into a 03 gtx 185
Shanekeery
Have an 03 gtx 4 tech limited good hull want to put a motor from a 07 rxp 215 with a bad hull wondering if it would be plug and play I have two complete skis
You will have to switch almost everything including all electronics and pump from the rxp. You will need an RXT driveshaft and you will have to modify your hood in the gtx to make the cluster fit but isn't too difficult. You should look closely at a 2007 RXT because that is exactly what you are building.
