4-TEC's......
You'll find most of the 4 TEC's parts are interchangeable with each other. I did some looking around the other day on the main parts like blocks and heads. The part numbers between the SC, SCIC and NA all matched. But, I'm sure there is some odd differences like bolt holes in a head that supports the brackets of a SC but not in the NA. But, in reality, it would only matter if you were going to SC instead of the other way around.
The piston composition of the SC engines verses the NA engines are different, but the sizes are the same.
When you get into the 08 and 9's with the 255 hp engines, you'll likely see some changes there. So, if you stick with an engine within a couple years of the one you got, you should be fine.............:cheers:
