stang69
Have been working on this 02 GTX DI issue for a while now. THere is a huge vibration through the motor, from idle to higher RPMm that is vibrating the whole machine. It has broken tuned pipes at the exhaust manifold and snap bolts that also hold the pipe at the manifold.
This what I have done so far with no solution yet.
All motor mounts are tight and secure, All mounts for tuned pipe are new and tight.
Pulled the Jet pump, prop and drive shaft last night and everything looks great.
Thought I would start the machine with the drive shaft our now to see if there was still a vibration. Same vibration thorughout the whole machine and sound, seems a little loader than it should be but this is in the garage with no water to it. Can feel the vibration on the body while leaning against it. Pulled the Mag side plug wire started it and same vibration, pulled the PTO side plug wire and same vibration. Pulled both and of course would not start. The idle and vibration and sound is the same running on one or both cylinders, seems strange but true.
The machine starts great but I am thinking there might be something internal in the motor that is wrong.
Has anyone else heard of this type of problem before?
