XPDI Electrical Issue…(Need Help)
jbradley
Measuring 13v at the battery and starter relay. Continuity checked everything in the ebox and all appears to be good. Just took the ebox apart again and cleaned all the connections and it appears that I’m losing voltage at the the lower left connection where the main relay exits.
Getting 13v off the red and measuring 10v on the black.
Reading 9v at the MPEM fuses. Any ideas?
Cleaned the ebox again and I’m reading 12v across everything. Still getting 9v at the MPEM. Is there another connection, relay, etc… that be causing this?
I was able to start the ski when I jumped from the starter relay.
Thinking now that my issue must be continuity in the cut-off relay?
I'll be taking out the ebox and swapping out the relay this weekend and will provide feedback in case it helps anyone with future troubleshooting.
