well i rebuilt my 787 with wsm pistons, i had 150psi before the rebuild but due to a large water leak at the bottom of the jugs i decided to replace the pistons while i had the jugs off. using the lowest crank gasket, 0.3mm i still get 2.1mm of squish when i should have at most 1.7mm my pistons are to short! i did a psi test on the bench and i only get 135psi now. the motor only had 175 hours and i didn't have it bored since the machine shop said the cylinders were still in spec, very little wear. this really sucks. i should have listened to the other post about wsm pistons...plus they were the platnium ones!
jeff
jeff
