Superneil018
951 Gtx limited 98.. just did the top end .. first time i had it in the water was today .. started out fine .. started the break in process.. couldnt get it to go about 5mph in the water and 2-3000 rpm... it would run as long as i wanted it to, but the engine would never just take off.. opened it up adjusted the carb and it sounded like it was idling great .. still wouldnt take off ... after a while it started leaking oil from the right rave valve... started right up every time .. would idle perfect.. got it home and checked the compression and it was 135-130... ANy ideas??
