All,
Have a 2008 215HP GTX w/ V-TEC engine.
Out of warranty, so want to do the winterization myself.
I got the shop manual, and started on the process, slowly.
Changed the oil without incident. think i have a handle on fogging the engine, since there's a little yellow adapter to spray oil into.
When it came to antifreeze, I am confused. The manual calls for pulling off two hoses, letting things drain, then pouring antifreese into the hoses.
The first problem I have is that those hoses simply aren't coming off; the top one has a permanent clamp. I guess I could cut it off and put a regular hose clamp on it. but, the lower hose has a regular clamp (these hoses attach to the intercooler, I believe). I took that clamp off, and hard as i tried, i couldn't budge that hose. no way.
so, a neighbor stopped by, and told me that dealers don't remove those hoses and pour antifreeze in, anyway; they hook up a hose to the connector in the back, that you'd use to flush the 'doo with a graden hose after riding it, and send antifreeze in that way, and stop when it's all antifreeze coming back out.
I sent antifreese through it in this way, not by removing the hoses. my question is, is this ok, or am i missing an important part of the winterization?
Any advice, either directly or indirectly related to my winterization attemp, would be greatly appreciated. after all, it's my first try at it, and i am still learning.
s
s
