Macky_rx-di
Hello all,
I recently saw that there is a loose hose in the engine compartment of my 2001 RX-Di. I tried to find the appropriate spot to reconnect the hose but so far I wasn't successful.
From what I found out the hose is connected on the other side to the second outlet on the left side on the hull (near the CSI Coolant System Indicator). If I recall correctly the outlet has a more yellowish color. (rather than white like the CSI).
Does anyone know where this hose is supposed to be connected in the engine compartment.
Some more side information:
The hose is routed underneath the air box and then misses a connection. The hose is aprox. 6 or 8mm in diameter and black.
Let me know if you need more information. I will try to add more pictures as soon I come home.
