Ryan727
So I've got a '99 & '98 GTX 951. BOTH of these fuel selectors leak out of the RES (reserve). This leak occurs when I take the selector off, switch the fuel to ON, plug the OUT hole with my thumb, then blow into the inlet.
So both were doing the same thing, I thought maybe there was some leeway there, and it wouldn't matter much. So I put one of them back on with my new fuel lines. I pull the carb's return line from the MAG, blow into it to see if I can get things moving around. The tank and lines hold pressure, but once it gets to a certain level, I can hear the selector whistling (can't tell you at what PSI, does it even matter?). I can also hear bubbling in my fuel/water filter. I assume there's too much air getting in there?
Anyways, I figured I'd replace the darn thing for $20. May as well. Everywhere I'm looking is selling what-looks-to-be exactly like mine, but then it says in big bold letter, "EXCEPT 951 MODELS".
So.. WHAT'S THE DIFFERENCE? Here's a pic, looking on SBT's site before I drive over there to get it:
