Ahhh Something that I know about to help give back,
http://www.bbcboards.net/bassboat-re...ome-sorts.html go to Checkmate Boats.com ,under Gel coat paint and grafics, there is that link there, under spraying Gel coat, Dont hang the Ski, drain the fluids, make sure theres no water in the box as well, and flip the big pig over, to repair the bottom, bondo glass is fine for filler, be prepared for days of sanding, you will want to true the hull, if its not done right you will have handleing issue from doing the repair work everything has to be true and level, if using a sander or Da, be warned you can quickly rutt out area's that you are sanding if not sanding right as the hull is not flat, just a slip when knocking down the repaired areas can gouge the steps or hull/keel, you want to do Gel as it is the strongest and hold up longer then any paint, but takes alot more time with sanding Vs. Painting, 2K is not Durible for any hull on anything, if going with a paint go with Dupont Imron or a cheaper version of that is Tamco's Duriflint 2, that I have used and recomend and its cheaper then Imron, Interlux makes a VC performance epoxy that is duible as well, but if I ever do another Ski it would be nothing but Gel coat as its the most durible, Do not roll and tip any paint, spray it on, if you are not Exp. with Shooting Paint or Gel, when it comes time I will walk you through it, as far as HVLP guns go you need a good one there is a big differance from a $16 harbor fright one and a Iwata or Satajet, you will also have to have a big enough compressor to handle the CFM of the guns output, or half way through the shoot you will be screwing everything up with low pressure and it will turn out like SHI%.
