Rocket7919
I've got a 99 Speedster SK, new to me. As you can see in the picture, the gel coat is worn off in some areas. I asked the previous owner about it when I bought it and he said it was like that when HE bought it. Today, I was underneath it, checking out some things on the trailer and I found two small cracks/holes. One is just in front of the intakes and looks like it was hit on something. The other is in the left of the picture, pretty much in the middle of the hull. The fiberglass IS worn thinner there, but only seems to be in that one spot where the water is coming from. I've checked the rest of the hull where the gel coat is worn off and there doesn't seem to be any dangerously thin parts. These two look like they've been leaking for a bit, but who knows. The hole to the left goes up into the middle of the engine compartment, inside the hump in the middle. The other one doesn't go anywhere, it just hits something solid past the sheet of fiberglass. I'm curious if I just patch and/or build up the fiberglass and I'll be good to go, or is there wood underneath there that's going to, or already is, rotting out. I'd say it's metal because of the rust stain, but I'm not sure. Anyhow, any and all thoughts are appreciated!!
