Looking for advice on a used XP. Which year to buy? My hx's had carbs and never had a problem in 16 years of ownership. Noticed the XP's came with injection in 2003 & 2004. With a stated 35% increase in gas mileage? Is this true? This would interest me as I like long distance riding. Not concerned with speed. I have cars to run fast with. If 60 is stock that is good enough for me. More concerned with reliability as my stock hx's were bulletproof and never had a problem.
I have sure seen alot of threads on new motors, bad cranks, won't rev past certain rpm, too many computer woes, bad reed valves... etc... SCARY!!!
Are certain years of XP's lemons? I would like the injected model if reliable and good on gas for distance riding...
As the skis are hi-tech, no problem, I have no desire to tinker with them any longer, hours of wrenching, bent over the hull is not my idea of fun any longer... Did that on my Si with all the high performance products. The HX's were only about 50 mph but was fine with me and what a scream to ride! I personally loved them! I like the XP for the reason it is just a larger version with a little storage and twice the fuel on board. I will be MORE than HAPPY to have the XP serviced yearly by a extremely competent SEADOO Tech! I do not want to clean the rave valves, grease the driveshaft, replace the wear ring, UGHHH...
SOOOO... as long as I don't try to use my very limited knowledge to service a good, used XP DI which is surely built to very high technical standards and I yearly have the pump oil changed, and everything gone over... Are the XP DI's bulletproof or should I go with an earlier carburated version? And if so what year?
Thanks for your thoughts and knowledge!
Dooingit Solo!
John
Dooingit Solo!
John
