S sweetEmbrace78 New Member Jun 7, 2011 #26 Just have a question im looking at a 95 seadoo sp the guy is telling me the compression is 125 whats the highest and lowest????
Dr Honda Well-Known Member Jun 7, 2011 #27 sweetEmbrace78 said: Just have a question im looking at a 95 seadoo sp the guy is telling me the compression is 125 whats the highest and lowest???? Click to expand... 125 is time for a rebuild. A fresh Seadoo engine should be at 150 psi.
T TFWildman112 New Member Jun 7, 2011 #28 right if it's 125 time to rebuild, just make sure your holding the throttle wide open when you test it makes a difference.
S sweetEmbrace78 New Member Jun 7, 2011 #29 TFWildman112 said: right if it's 125 time to rebuild, just make sure your holding the throttle wide open when you test it makes a difference. Click to expand... I've heard that before but was wondering why?
T TFWildman112 New Member Jun 7, 2011 #30 If you leave the butterflies closed differences between cylinders in the carbs might make a difference in the compression numbers. If you open the butterflies you remove that potential difference from the equation.
