Not without damage....
will these engines even run on E85? I was referring to E10. Down here in Miami i have yet to encounter a gas station sellin Gas without any contents of Ethanol. So although im pumpin E10
. I still pumped premium with Stabiul Ethanol formula which reduces or eliminates the the damage that gas with E10 can produce.
The research shows that if your vehicle has not been designed as an FFV vehicle, which means all the rubber "0" rings removed and a suitable substitute installed, then your likely to cause damage over the long haul.
There have been literally thousands of complaints lodeged to the government about the damaged vehicle fuel systems because the owners had extensive fuel damage from water that leached from the alcohol that makes up the flammable side of the E85. The other problems is, alcohol melts rubber. So, any parts in your fuel system exposed to the E85 will eventually damage it.
The auto industry has made advances in changes vehicles fuel systems, which they now lable as FFV vehicles which mean, they are certified to use E85.
The Rotax engines are not E85 certified and will likely see the destructive results in a year or so of constant burning of thie biofuel.
Below is a paste and copy of research I did a week ago from a couple sites on the internet that had answers to peoples complaints about the moisture damage to the sensitive parts of the fuel system that was damaged and alcohol melting other sensitive parts that sealed with rubber "0" rings.
In my opinion, I would not use any ethanol based products until a complete and throuogh study has been performed to prove to us it is safe for teh expensive fuel injection systems and sensors of our motors.
READ ON:.......... Depending on composition and source, E85 has an octane rating of 100-105 compared to a regular gasoline's rating of 85-93. So you can see right here that this fuel is not meant for the Rotax which states in the shop manuals to use 87 octane, 91 in the 4-TEC's. The higher octane rating will allow it to be used in higher compression engines which tend to produce more power per unit of displacement than their gasoline counterparts. Since the reciprocating mass of the engine increases in proportion to the displacement of the engine, E85 has a higher potential efficiency for an engine of equal power. What this means is any of the Rotax's that are modded out with extreme racing cranks etc....can use the E85 more efficiently than our stock motors. You can see this in drag racing. These drag boats use methanol, alcohol or some other type of alcohol blend.
One complication is that use of gasoline in an engine with a high enough compression ratio to use the E85 efficiently would likely result in catastrophic failure due to engine detonation, as octane rating of gasoline is not high enough to withstand the greater compression ratios in use with an engine specifically designed to run on E85. So this too is proof that our engines are not equipped to run the higher combustion it takes to completly burn the fuel.
It is a proven fact already that E85 has a lower mile per gallon rating than gasoline.
One of the biggest reasons for us to switch to a biofuel was the environment, outside the fact that we need to start finding alternative fuel sources. Scientists first thought that biofuels were good for the environment because it had a smaller carbon footprint, which might be true. But, the production of grain alcohol itself is not environmentally sound. Burning it is but making it isn't.......
All my research comes from websites off the internet. The material above was summarized therefore, not cited. I am still gathering information that I will eventually use in "Snipes Korner" but for the moment, it seemed a good idea to throw a little into this thread.
Bottom line,.......I don't care if I have to drive an extra 25 miles for pure gas, I will. The only way I'll burn E85 in my vehicles, lawnmowers, or Seadoo's is if the government leaves me no choice
