C180 Stereo upgrade.
My new project listing for today is an updated Clarion head, cut out speakers in the front for 6.5 as well as a sub in the common area on the wall of the port side. I went Polk Audio Db series all around with 6.5"X4 and a 10"x1. I'm running the four speakers off the head unit and using a cheap 2 channel for the sub until I can find the right marine grade amp I want that won't cost $300.00
Amp was mounted in rear hatch against wall that the air box used to be attached to for ease of access to the manual controls and additional air space to keep it cool when parked.
The OEM remote wire wouldn't work (my ride is a 2007) and the hole was to small for the remotes I bought...so rather then (painfully) fish the wire to the drivers console and cut a larger hole I went with the transom mount of the LCD remote. I then got the 2nd wireless remote which will mount in a blank space on the console as all you need when driving is volume.
I added a 2nd battery for the stereo to suck power off of the deep cycle. I'm using a Battery Doctor isolator/charger which is great as you don't need to add a 1/2/Both switch...and you can keep the OEM. Simply hit the manual button if you need to combine batteries for an emergency start. I've put Battery Doctors in 3 previous boats...swear by them especially for the price.
I've got an online supplier of the clarion remotes, wires and y-adapter that is half the price off all other retailers. PM if you need a link.
PS. The 2" hole left behind by the old OEM remote was replaced with a 2" digital voltage meter.
NOTE: Yes I know my double battery wiring is a mess...it's in template mode. Will clean up and add some battery terminal covers for safety.
