Ok, so most of you will probably be laughing here shortly, If you noticed my ID, yea I got one. Its a 97 GSX, actually felt like I stole one. I went to look at this thing off craigslist guy said marine mech told him it needed a new switch because it would`nt do anything. He had purchased a new battery for it and yea i could see that. He further stated him and his buddies had been jumping accross the solenoid to check the compression and said it was good, around 140 or so on both cylinders. I`m thinking all this does not sound to bad but he still wants 1400, because kelly book is around that not counting the really sweet looking shorelander its setting on, probably worth 250 or so anyway. (sorry this is becoming long winded but bear w me) so anyway I decide not knowing jack about a seadoo I`m not giving more than 750, but i tell this guy i only have 500, he tells me go try and get the other 250 and call him back later. I leave. 2 hrs later he calls me up telling me to bring the 500 before he changes his mind, he`s found a 350ci motor down in KY. to finish a firebird sitting in his driveway. I do it. I get this thing home it is full of rank gas, tag expired in 08. I figure thats how long this thing has sat.
So now comes the good part, right, Thanks to this WEBSITE I found the 5 amp fuse in the front (grey box) that they blew jumping accross the solenoid and I replace that, my gauges all start working the hr meter shows 125 and the maint indicater is flashing, which I reset following directions from this WEBSITE, I proceed to drain the gas out and replace w fresh, oil drained and replaced w fresh, I reach up and hit the start button, and looking at things while cranking I begin to see "bubbleing liquid" around the head bolts. Its about this time I realize those bolts have the paint chipped off from having a wrench put on them, "I guess" so I reach in to try and turn one of them, It turns with only my fingers, OH MAN, all of them are only finger tight (or loose) so I remove the head just knowing the rings or the pistons or maybe the block is going to be destroyed, i`m beginning to feel sick as I lift off the head, WT? I can`t see anything wrong with any of those components. I hit the start button w the head off, It spins over like crazy throwing watery fuel/oil every where. (Again sorry for the length of this post) but I`m trying to give acurate picture. I decide to clean up the mating surfaces and put the head back on, But before putting plugs back in I mixed some fuel and oil in a cup and while holding the throttle wide open pour several half cups through the carbs, I cranked it repeatedly allowing that fuel/oil mix to fly out of the spark plug holes, which it did everywhere! after a few rounds of this I decide to put the plugs back in, I held my breath and hit the stater, It sputters to life, throws this huge splash of water out on the ground, and dies. So each time I hit the starter after that it gets a little better and runs alittle longer. Of course I can`t keep doing this because I`m sitting in my drive way. So the next day my son and law and myself take it to the river close by and this thing is kinda chuggleing along until it gets to about 4k rpm then it just becomes "hold on" cause it is flying accross the water all the way to about 6800 rpm, i`m freaking out, this is great. well that lasted about an hour then it would not quite reach 6k, then about 5k and pretty soon about 4200 was max, just like running out of fuel, I was pulling the choke to see if it would get more fuel only made it die out sooner, I know about the little screens in the carbs, BUT after sitting for a couple yrs with blown fuses and rank gas, I`m "finally" asking What else would be the wise things to do since its going to have the carbs off, should I CHECK? REPLACE? SERVICE? I am open to any and all suggestions, its this WEBSITE that has given me the confidence to do this thing right. So let me have it! Things that might happen or what to look out for would truely be appreciated. Even the most mundane advice, I`m ready,,
