I have a 2006 205 Utopia SE (twin rotax 155). I changed the oil in both engines this past weekend but following the instructions I've found online with one exception. Putting the throttle all the way forward did not "turn the engine over", so I basically had to start them after each extraction. However, they never ran for more than .5-1 second. After getting what I believed to be the bulk of the oil out, I added 2.5 quarts to each engine. I then decided to crank the engines for a few seconds to cycle the fresh oil through then recheck. When I cranked the engines, they ran for about 5 seconds (at most) and the starboard engine started making a loud screeching sound so I immediately shut them both down.
Does this sound like the engine or the jet? Is it possible that something got sucked into the jet causing this?
Thanks in advance!
Mike
Thanks in advance!
Mike
