Seadoo's don't have water flow indicator, aka pisser.Yes they should be there. Typically battery vent, cooling water flow indicator and possibly fuel tank vent.
pretty sure mine has one lolSeadoo's don't have water flow indicator, aka pisser.
old 2 stroke?pretty sure mine has one lol
Old 2 strokes piss out the back, my '96 has a pisser out a small hole under the U bolt tie down.old 2 stroke?
Depends on the model, a lot of the 2-strokes piss out the side too.Old 2 strokes piss out the back, my '96 has a pisser out a small hole under the U bolt tie down.
That’s a good one , thanks, well I actually tried, probably not that hard, when looked inside the hull there is styrofoam above the level of those holes and I didn’t see any hoes coming out of there either... anyways thanks for the hintHello Igor, that is your built-in vision test system. Place your face close to the hull, with one eye positioned in front of each nipple, and then start the ski. It will run a test and will provide tactile feedback (if it hurts you can be sure that you're not seeing well).
Or, outside of my over-active imagination/sarcasm gland, take the seat off and LOOK inside the hull to see what's connected to them. I guess a cooling flow indicator and a battery vent.
I should’ve clarified – I was responding to the post that said seadoo doesn’t have a pisser.no pisser on the 4 strokes
