Just fitted a new wear ring to my xp 951 because the old one was a bit chewed out.
The trailing edge of the impellor was straightened at the same time.
Now it's all back together the impellor seems to be tight in some places and you can see light in other areas.
Waiting for parts before i get the ski wet so don;t no if it will be better.
My local mechanic reckons the pump body can get out of round/warped by a lots of wave jumping ?
Is this true ?
Should the clearance be the same all round the impellor ?
Is it normal to need a new pump housing when they aren't obviously damaged ?
I was expecting practically no light to be visible through the pump with a new wear ring. Is this what i should be expect ?
Thanks
Phil
P.S - not sure about the new forum structure ay
Is this true ?
Thanks
Phil
