water in cylinders
lilpain
I have a90 sp that has water in cylinder possible in crank .head gasket looks pretty wet its never been flooded what can cause this thank u.
It could be lots of things...was it running when you discovered it stopped and water in the cylinders? Did you run it on the garden hose with the engine off? Has it been sitting for a long time? Do you get freezing temps there and it wasn't winterized?...it could be lots of things give us more information so we can help you out.
Karl
i took it apart today and then base cylinder head gasket was ript can that be the problem,it yes its been sitting for 6 monts
