water in hull
crshnbrn
i have a problem when i take my sea doo out within 5 to 10 minutes the hull fills up with water and it almost sank it but when i leave it on the trailer and back it into the water where its all in the water and i start it up no water comes in the hull only when i have it on the lake and running it out there it fills up with water i appreciate any help i can get thank you
what hose pumps the water in through the motor because whatever it is thats filling up my sea doo hull its pumping it in from somewhere and not pumping it out
i did leave it on the trailer and put it in the water but when i started it no water came in the hull only when i take it out the water comes in i guess i will have to take the seat off and take it out but it fills up really fast so it will be a short ride thanks
Possible damaged carbon seal
if the carbon seal was damaged how fast would the water come in the hull because it fills the hull real fast what ever it is its pumping the water into the hull if i have it on the trailer theres no water coming in only when i ride it
Really fast. As that is the coupling between the pto shaft and the fiberglass hull
It sounds like you have an exhaust cooling hose maybe off, if it is filling up with water that quickly. Maybe the leak isn’t totally obvious or large enough with the ski just idling on the trailer in the water, and it is under acceleration on the lake that you notice the hull filling with water? I would touch, pull, inspect every hose clamp and hose from the back of the hull where it connects to the jet pump, to the exhaust manifold, and then to the muffler box and out of the ski. You can have a leak before the exhaust manifold that fills the ski with water, but then you would typically get an exhaust overheat warning. So I think your leak is after the manifold, maybe in the muffler area, and somehow water is not exiting the ski. Riding with the seat off is maybe needed, and might need a buddy to kneel at the back of the ski and look down inside with a flashlight to see if they see water coming in while accelerating. Hope you can find the leak!
i want to thank everyone for the help. it was the carbon ring i took the seat off and took it out on the lake and at first it didnt do anything but when i got on it my but got soaked and i could see the water coming out from the carbon ring real fast so thanks everybody now i have to replace it
Have you been running the ski on the trailer for more than 2 minutes?
Nice! Congrats!
My new (only 20 hours) 325RXTX is filling up the hull with water, about half way every 10 minute ride! There are also a lot of rubber beads all over the back side. Please Help!!! See pics.
I'd start a new thread concerning this as it may prove useful for others. Sounds like something got disconnected. I agree with the poster that said take it too the dealer. I am paranoid about water getting into the engine compartment... they DO NOT like water in the bilge. Nothing good will come of it.
