I have this problem when I go to shallow and suck up sand, I have found that removing the hose at the end which you have circled red and at the other end then using a wire hanger to push out the sand helps to open up you "pee" hole. Also, if the sand is packed in their tightly beat the hose against a hard object and this usually loosens up the sand and throws it out.
