that's the clamp on your carbon seal.  It should be just tight enough to keep from leaking.  If you make it too tight, it could crack the ring.
It's going to vibrate because the inside bore is bigger than the drive shaft, and it just slips on the stainless ring.  If it's out of water... there is nothing to lube it, or cool it.
