I have been searching and searching for the answer to this but have been unable to find a definitive answer. I have one simple question. Do I need to disconnect the cooling hose and bailer hoses on this machine? The service manual says nothing about removing them but everywhere I read it seems to indicate they need to be removed. The jet pump seems to have a joint for these (likely an o-ring behind) and therefore I do not believe they are attached to the JP.
It sounds so simple:
1) Remove the cooling hose from inside the hull. (and bailer hoses if you have them) They are on the transom, and held on with hose clamps.
2) Remove any cables hooked to the pump. (Steering, Reverse, and VTS)
3) Remove the nozzle. (4 bolts)
4) remove the pump. (4 nuts)
The next problem I have is I have a bunch of sealant oozing from the JP and I suspect this is what is preventing this from just slipping off. Or as the manual says: Remove jet pump with a wiggle movement. Yeah right! :cuss:
So I am appealing to the experts on this forum before I build a jig and start pulling............:thumbsup:
