On my 96 GTX, I have a weak spot that exists just on the tuned pipe head that I need to weld shut. Following the manual I removed all hoses (bleed hose and water hoses) from the tuned pipe as well as the clamp holding the tuned pipe head in place to the rest of the tuned pipe assembly and the 4 screws holding it in place on the manifold.
I only need to remove the tuned pipe head, which appears perfectly possible at this point, but it will not come off. It seems as though it is stuck and something is preventing me from separating the tuned pipe head from the rest of the tuned pipe. The diagram does not show anything should be in the way at this point and gives the impression the pipe head should come right off.
Is there something I am doing wrong? There looks to be an orange rubber seal(or epoxy maybe?) that is holding the tuned pipe head almost like it is glued to the rest of the tuned pipe. I don't want to remove the whole tuned pipe as it seems unnecessary at this point if the head alone is supposed to come off.
Any advice is appreciated!
Thanks,
Seth
Thanks,
Seth
