Took the cone at the end of the jet off and grease came out
floquito007
i am fixing the ski for a friend. one rock was infront
after the intake guard and one at the end. i took the cone at the end off to get it out. once i had the cone off grease came out.
question: how and where do i check if i need to ad grease what is it for?
thanks for the help.
here is a picture of the cone maybe this makes it easier. If it is the oil, how do i check it and change it.?
Jet Pump Oil
You keep saying grease, but it should not have any grease in there. It should be filled with gear oil. Do a search on Jet Pump Oil Change and you should find instruction on how to change it. You can use Mobil Synthetic Gear Oil – 75-90W – GL5. It's relatively easy to replace.
cool thank you so much. oh since we talk about it. i also saw that the engine oil is white so i guess there is water in it as well. how to i change the engine oil? do i need to put it out?
Gotta pump it out. make sure to change your filter also. If you have water in your oil thats a bad sign. may have a blown head gasket
DO NOT PUT OIL IN YOUR JET PUMP!
Only the 2-strokes use oil in the pump. All 4-stroke Sea-Doo's have grease in there. If the grease is clean, just leave it.
Chester
Agreed with Chester. ONLY 2-STROKES USE 90 WEIGHT SYNTHETIC GEAR OIL!!! 4-Tecs use a type of synthetic almost like a wheel bearing grease. If the cone is low fill it up with more grease. You need to check this just about every season! If not thats about $600 worth of parts.
wow thank you so much. well i know it was grease that came out. after all the answers about oil i thought the dealer did something wrong.
thank you all i am glad i did not fill it with oil.
