I am looking at a 2001 Challenger 2000, the boat is just like brand new with very low hours.. I was pretty exited about getting this boat untill reading all of the posts about starting problems with the 240EFI. Is the motor really that unreliable or am I just reading about problems instead of good things. I really would like to buy this thing but kind of scared now.
I was told that if you had a 240 EFI that idled right over 1000RPMs in the water not to buy it PERIOD. They had a bad run of 240s early on and there was no fix for the low idle/not enough power to run the system issue.
Ok so I took the Challenger to the water today and it idled in the water right at 1000RPM's... Does this mean this boat is OK.. I also took it to my local dealer and it has had the fuel filter and voltage regulator campaings done. Also there were no other campaings that the boat needed done. I tried to pull the hours off the PCM but dealer said 2002 model was first year with the option to check hours (Motorola PCM).. I know the person selling the boat and he has never had a minutes trouble from it and when I took it to the water and ran it with multiple starts if performend flawlessly.. Going to take it to the lake in the mourning if there is anything else I should test please let me know. I wouldn't be so concerned about this boat but it is truly in new condition as well as the trailor.. It looks like it has never left the garage.. Please help me make a decison on this 240EFI, because the rest of the boat is perfect...
Thanks
Thanks
