Dr Honda
i've read how bad some of the handlebar pads get on x4's and mine was no different mold/mildew spots all over it, tried soft scrub, brush, cleaner after cleaner with no luck. water/clorox mix soaking for almost a week cleared it up. Prior to using the clorox mix i tried abrasives and it just started to scratch the cover, worked great highly recommend it!
The best way to clean it is to use Zipo Lighter Fluid. Just squirt it on the pad, and wipe. It will look like new.
The reall issue with the pads, is that the rubber they are made from decays, and gets gummy. At that point, you can't save it.
