KyleB
Hey guru's. Been reading your X4 thread. I bought a couple older jet ski's at the end of last year. A 97 GTI and a 99 GTX. I'm no expert on these puppies, really a novice but getting to know them inside out very well. Been using them quite a bit this summer. The GTI is down right now, I replaced wear ring and tightened it up so much the drive shaft / pto-flywheel both stripped splines. Waiting on parts now. The GTI is nothing compared to the GTX, looking for another ski like the GTX. I'd like to get your thoughts on a ski i found on craigslist near me, I put a deposit down on it already so don't anyone get the idea you can get there first! Please let me know your thoughts, just feeling around in the dark, but I really love these ski's.
http://sanantonio.craigslist.org/boa/2535438814.html
The add says good compression. If I were you would would take a tester and just check. It's very easy to do and the owner shouldn't mind it one bit since he is wanting to sell. Anyway, take off one plug and put it on the ground post, remove which ever plug for the cylinder you are going to check and turn the engine over with your compression tester firmly seated in the plug hole. Each cylinder should be pretty close to the other and no less than about 135 PSI each. I agree with PPE and tell you that if you are expecting the XP to ride somewhat close to the GTX or GTI that you have you will be very disappointed. Don't get me wrong the XP is a blast to ride just completely different than the bigger boats. Also it seems a bit pricey at least for Alabama it is but you are in better shape to determine what the market is in San Antonio. Hope this helps.
