I could be off base but does the gauge move, light up do something when you hit the start button ( I didn't read the entire post)? The plug has to be plugged into the front of the mag housing to complete the ground circuit. If not the electronics will be dead in the water. I think someone asked about the little ground from the rear e-box to the battery. I think you said it was hooked up----does it actually make continuity INTO the grounds INSIDE the rear e-box? Gotta make a ground all the way in.
