the 100 dollar 95xp project
this is the 2nd 717 engine ive seen that lost a wrist pin brg( some of u may remember the gti that we borrowed n blew up,and rebuilt)
def goin to need topend,a cylinder,ill get a crank for it(no reason not to have the peace of mind),i think i can clean up the head(what do u guys think), was thinkin send it to fullbore,295 for topend with bore n gaskets,
hey racer,,u have to be the crafty-ist inexpensive parts finder on here,,can you point me at a good rebuilt crank?
ill go pull the motor out n check the rotary valve n cases n post more
Here's what I could turn up.
OEM 717 Reman crank for $393(there's a $200 core that is refunded, ask how soon you get that back), An SBT is $275. Personally I'd pony up the extra $100 for the OEM unit, you already know the life expectancy.
http://www.2wheelpros.com/oem-parts...74-part.html?gclid=CJDIkKDL0LUCFQdU4AodsTwAJQ
Here's one OEM SECOND over size piston for $60 shipped (that's half price and a less then an aftermarket)
http://www.ebay.com/itm/BOMBARDIER-..._Watercraft_Parts&hash=item3f1539867a&vxp=mtr
And here is the other one. Use the make offer for $40 and let them counter to $50, and you got another one for $59, so you just got a buy one get one free pricing.
http://www.ebay.com/itm/NEW-SEADOO-..._Watercraft_Parts&hash=item336be141f8&vxp=mtr
Here's the wrist pins, make offer of $15 each, so again almost buy one get one and he's offering free shipping!
http://www.ebay.com/itm/NEW-OEM-SEA..._Watercraft_Parts&hash=item2c64ff3570&vxp=mtr
Here's the OEM wristpin bearings 2 for $30 with free shipping, again an almost buy one get one
http://www.ebay.com/itm/Bombardier-..._Watercraft_Parts&hash=item4170fb0fa6&vxp=mtr
And her's the cream of the crop, A full OEM gasket set for $60, but wait we'll throw in the extra gaskets in the second pic!!!!! I wouldn't even haggle on the $60 that is $90 off OEM PLUS the EXTRAS!!!!!!!!!
http://www.ebay.com/itm/SEA-DOO-Gas...Parts_Accessories&hash=item3cbeaeb805&vxp=mtr
So, what else do you need??????? :D
Please guys don't jump on these parts unless Donkey says so. And hey, that's cheaper than all get out. Get a clean jug and head then pay to have the cylinders bored and your good to go! OEM for aftermarket prices. Just please verify all the part#'s, I used the fiche to get them but I don't want to be held responsible ;)
Just for the quick math, that's $650 for OEM parts, figure $100 for a bore job, head for $40, jug for $75. So $865 for a complete engine with OEM goodness. A total of $120 more than SBT, but wait, I think shipping from SBT is $120--so that's even!
Dont forget to call your local dealer and see if your tank has been replaced, if not you are getting a new gas tank for free.
Or call brp directly at 715-848-4957 then hit option 5 Just have you HIN ready
wow,,told everybody racer was good at that! thanx for your time !!,ill start buying soon.
jsg- good call on the fuel tank,,ill check that tomoro
Thanks man, it's really like 20 minutes of work. It's a part# and Ebay and Google. I know guys hate Ebay, but when you can score OEM stuff for that cheap, how could you possibly hate it.
Check my other post. And remember to check the part#'s please
as i was taking apart the engine,it was obvious,that someone had recently replaced only 1 cylinder(mag side,in the pik its marked 717).
so they messed up something or missed the cause for the inital failure.possible carb lean,or case leak im thinkin.u guys agree?
and yes racer,,ill double check all the part#'s before i pull the trigger,,thanx again,
troy
starting to go thru the carbs,pressurized the fuel line going into the carbs.i put 30psi on the gauge,and heard hissing from the mag side fuel line.(yep,grey lines and factory clamps).so theres a lean condition,from sucking bubbles,instead of fuel,right?
Not sure if your interested but I swapped from two carbs to one on the 717. All 3 of my skis.
Makes things easier.
You need to get single intake and single carb air intake with bigger main jet and your done.
Problem is orientation of carb is different and you lose choke cable.
none that I feel.
Never had dual carbs to compare.
Went from seadoosouce reference chart .
My boat with 717 have single carb. Didn't see why ski had to have two??
i dunno.im pretty handy with carbs, so i think ill stick to the stock setup.dont wanna spend a ton of extra dough.but ya,the gti we borrowed ran good with a 717 single carb,( in fact i remember the gti ran real good,cant wait to ride this one!),and the 92sp single carb ski rips.
Not as much as you think.
Save you a carb rebuild kit........
Ask nick for a quote
:rolleyes:
From what I know the single carb is more fuel efficient and that was the main reason for the change. Ocod is right though, Saves $75 in carb parts on rebuild.
Twin carb should have a slight acceleration advantage over a single in theory.
when i got the engine apart,i found the rotary shaft gear missing teeth,the rotary crank gear off centered on the crank,and it looks like the end seal was leaking.cant find a reason for the gear to be stripped,possibly,when it failed the first time,they didnt see it.also,no needle brgs in the bottom end.pto piston had oe needle brgs,mag side had caged needles.
someone really tried to patch this thing,HACK!
That sucks, at least you know what your in for. Like a patch work quilt, she was made from scraps!
its actually cool.when im done i wont have any worries about someone elses work,ill have done it,and it will be right. i wont have to worry bout old cranks,pistons,seals,oil lines etc.plus i get to show and explain this to my son nick,who is helping with the work,and who is the designated jockey for the ski!
2013-03-30 17.12.12.jpgwell,its all together! runs pefect,(on the stand)did have 1 issue at first start,
when it started and i held the pump wide open,the mag side hose filled quikly,the pto not so much.it also had a bit of "unsmoothness" to it when it revved.i found the pto oil line banjo bolt loose,injecting oil into the hull and sucking air.tightened the banjo bolt,oil line filled,the miss went away.obvious vacuum leak causing the unsmoothness.(miss)
i am super pissed that i was sooo anxious to make it run that i didnt paint the engine!arggggg! i will pull it,paint it,n put it back in.goin to lake test all 3 skis this next saturday,wish me luck! oh and for you cold state guys,sorry,havasu should be in the 90's saturday!
thanx to everbody for the help along the way,special thanx to minnetonka for a bunch of parts,he's been pretty great!
troy
Donkey, I didn't realize this but we have both been rebuilding a 95 XP at the same time. I just finished mine this past weekend, but haven't posted any pictures on it. Mine had many, many issues, but the engine was solid with exception to a case leak. Congrats on the ski!
we still have snow on the ground here, & highs of only 40, so it will be a good 6-8 weeks before I am water testing mine.
Do you have any more pictures to post?
You son of a ...... It's 9 degrees and 2' of ice on the lakes as I type this.
Just kidding, the ski looks great, that's great that you were able to work on it with your son.
