I've got a 2011 GTS. around 350 hours. The splines are almost completely stripped on the impeller and the drive shaft. After I pulled the pump and shaft I noticed wear on the shaft and found it had been rubbing on the carbon ring. Is my engine way out of alignment or did the play caused by the loose spline allow the shaft to float into the carbon ring. The pump was not loose when i pulled it off. bearings and wear ring look good. Wear ring has very minimal and even wear.
Thanks guys
Thanks guys
