supaflygti
Hey everyone...quick intro...I just bought my first ski for the hell of it. I've raced motocross and had in the neighborhood of 20 mx bikes, quads, and street bikes. I recently purchased a 93 GTX for $200 that was thought to have a costly electrical issue. For what it's worth, the ski is in great shape for its age and I would love to get it somewhat reliable as a second machine to use (plan on buying a newer boat as well). Anyway, I brought the ski home and went through all the connections looking for loose or broken wires. Everything appeared fine so I replaced the plugs with (2) NGK BR8es which I'm pretty sure should have been BR7s. After cranking for quite some time the boat finally fired up and idled perfectly. After the initial start I can kill the motor and fire it up effortlessly time and time again. However, if it sits overnight it damn near drains the battery getting it to start again. Again, once started for the first time it fires up without a problem. When I ground the plugs I can't see even the slightest spark. Any idea what would cause this thing to be horrible to start after sitting but fire up flawlessly after the initial run? Thank you in advance to anyone who helps!!
