the problem is that it most likely will displace oil in the injection system... meaning your now getting diluted oil in the system and risk running w/out proper lube, it's painful, burns, and she won't like it... i mean your engine .
OR... you could... since that stuff is flamable. just run pre-mix and run your oil as low as possible, then add all new fresh oil once you've run enough out.
you'd be running oil rich, but that's a hell of a lot cheaper than running oil lean!
Thanks, I was planning on draining it but wanted to check first.
I'd drain it.
you'd be running oil rich, but that's a hell of a lot cheaper than running oil lean![/QUOTE]
