Split sun pad 2008 Wake 230
Ricardo J.
Hello everybody , I am in the process of restoring a 2008 Wake 230 that is completely missing the sundeck pad over the engine cover, that flips over half way for passengers to walk through.
Any idea where I could get the base with hinge on the starboard side swell as the other fixed part for the sun deck ?
You're in the correct section.
You could always you run what you have up to an upholstery shop and see if they can recreate what you're missing. A competent shop should have no problem doing so.
Oops, sorry. when I got the email notification, I assumed it was for the Jet Ski forum (the only one I'm registered in). If it's just missing the foam and pad, an uphostery shop should be able to help. If it's missing the frame (hinged base), I don't know where you would get that.
