Speedster "Pee Holes"
JLO73
This may be a stupid question and I did search for an answer before this post. There is a hole on each side of the rope mount. When engines are on, water only comes out the port side hole. Should I be worry it is not coming out of the starboard side? When I attach a hose to the rear to flush, I am getting good water flow thru the starboard side exhaust and pump housing.
Anytime you have an obstruction... you should be worried enough to figure out what is wrong.
:agree: Check the hose inside the engine compartment, it might be off and just dumping the water into the bilge.
All the hoses were connected. Took it loose at the engine and blew it out with an air hose. Had some junk in it. Got it clear now.
Thanks for the replies.
