I am not an electrical pro, but 1st check that the paddle wheel is there,and therefore that is not an issue. To rule out the sensor, disconnect the plug at the rear of the hull, and then connect your meter to volts DC, then spin the paddle, and you shud have a reading. If this positive, then check for power coming out of your mpem, if this is positive, then, likely, it could be the gauge cluster going.
