yajblackburn
So after recently getting a 1994 Seadoo Sp, I started thinking right away on how to modify it for freediving. The first challenge was to figure out where to put the gun, fin, float etc. After research I found people with large box type configurations to the rear of the ski. I didn't think this would work properly as it would get in the way of reboarding from the rear. So my next idea was a tow sled of some sorts. I found a bright orange winter sled at the local thrift store for dirt cheap, figured what the heck. It so happens my dive float fits perfectly in the sled. The only things I'm worried about are the sled filling with water and the sled flipping over. The gun is connected to the float, so if it falls over it shouldn't be a problem. So I put bungees over the float, gun and fins to hold it down tight, I haven't tested this yet so I honestly don't know how it will work....plan on testing this week.
The second thing was installing a fish finder. I tried to research on how and where to install it but came up with minimal results, so I thought I would just try it on my own. Luckily I was able to take some pics to hopefully help out others who might have the same issue. As for the readout I used big suction cups attached to the base to stick to the small area next to the kill switch/starter button. This method works well as it can be removed very easy and no holes are drilled anywhere. As for the transducer, I was able to fabricate a bracket to mount to the jet pump housing. It's not hindering any movement what so ever, but I haven't tested the function. Seems it would work fine, but "seems" and "actuall" are two different things......
