Hey all.
I have a 2004 XPdi. Great machine. Been playing up inconsistently over the last few months. (Bogging out without warning but would run perfect most of the time). Changing the plugs over as I type, however, thought I would just do a quick resistance test on my spark plug leads as the plugs that I am about to change are only 10 hrs old.
So the results of my test on the leads are Mag side 4220 ohms PTO side 6110 ohms. Manual states replace the lead if Mag side over 5700 ohms and PTO side 4300.
So... my results are pretty much opposite than what they should be. The mag side is the cylinder at the front of engine closest to the mag / flywheel isn't it? Am I missing something? Or is my pto lead shot?
Or has my manual got the figures back to front. I would of thought the longer pto lead would have more resistance than the shorter mag lead. I'm confused!
As a final note. The manual says to "always replace the leads with genuine ones otherwise fuel injection system operation will be impaired". How is this so? Leads $80 each
